Rought Idle
Old Dec 21, 2000 | 11:18 AM
Joseph Andres's Avatar
Car: 1991 GTA Convertible
Rought Idle
Just got done adjusting the valves after a ZZ-9 install. The car idles rough when I first start it and the engine is cold. After a few minutes of warming up the car idles fine, just a little lumpy for the ZZ-9. After a while of driving the car runs beautifully. When the car gets to operating temperature it is fine. I have noticed that the rough idles get better and better after I drive the car some more. Does this mean that I need more PROM work now? I have no SES light. Or does it mean that I just have to drive the car some more so that the computer adjusts?? I have driven the car for about 3 days now and the rough idle on cold starts is improving.
1988 GTA 5.7L Auto
355 ci. block, SLP Cold Air Intake w/ K&N, fully modified MAF Sensor, TPIS 52mm Throttle Body w/Air Foil, Throttle Body Bypass Hose, Fully Ported and Polished Plenum, Nikel-plated Ported SLP Siamesed Runners, Ported TPIS Big Mouth Intake Manifold, stock heads w/ 1.52 Comp Cams Self-aligning Roller Rockers, TPIS ZZ-9 Roller Camshaft, TPIS Valve Springs, Cloyes True Double Roller Timing Chain, TPIS Adjustable Fuel Pressure Regulator, Balanced Bosch 22 lb/hr Fuel Injectors, MSD 6AL, Taylor 10mm Wires, Bosch Platinum +4 Spark Plugs, MSD Blaster Coil, March Underdrive Pulleys, 6 3/4" Vibratech Streetdamper, TPIS Level 3 PROM, 160 T-stat, Low Temp. Fan Switch, Stock Distributor w/ Bronze Gear, SLP 1 3/4" Headers, Random Technologies High Flow Cat., Adjustable Borla Cat Back Exhaust, Level 10 PTS-3 700R4 Trans, B&M Holeshot 2400 Stall Converter, B&M Trans Cooler, TCI Aluminum Finned Trans Pan, Torque Converter Lock Up Switch, 3" Balanced Aluminum Driveshaft, 3.73 Richmond Gears, Auburn Pro-Series Differential, LPE Aluminum Differential Cover w/ Main Cap Preloads, BF Goodrich Drag Radials, Hotchkis Lower Control Arms, Hotchkis Panhard Rod, Hotchkis Tie Rod Adjuster Sleeves, Bilstein Heavy Duty Shocks and Struts, 1LE Springs, Energy Suspension Polyeurethane Bushings, Global West Tubular Subframe Connectors, Global West Steering Box Brace, HP Motorsports 3 Point Strut Tower Brace
"Why ride a stang when birds can fly?"
Old Dec 21, 2000 | 11:21 AM
I forgot to mention that the car's battery was discinnected for a month.
1988 GTA 5.7L Auto
Old Dec 21, 2000 | 11:27 AM
hello?
1988 GTA 5.7L Auto
<a href="http://www.geocities.com/thegta">My 88 GTA </a>
Old Dec 22, 2000 | 05:38 AM
Ski89Z28's Avatar
Joseph,
Check your post on the TPI Board.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
