SHIFT KIT ?
Old Dec 21, 2000 | 09:30 PM
CAMARO-90-RS's Avatar
SHIFT KIT ?
I RECENTLY INSTALLED A B&M SHIFT KIT. I WAS WONDERING IF THERE WAS ANY WAY TO TONE DOWN THE FIRMNESS OF THE SHIFT WITHOUT SACRIFICING PERFORMANCE
Old Dec 21, 2000 | 10:21 PM
CrazyRob75's Avatar
I've alwaays heard bad things about the B&M shift kits. If you set it up as stage 2, that means you removed all the accumulator springs resulting in really harsh shifts. I've heard everything from cracked forward drums input/output shafts, even cracked cases. Basically the shift is to damn harsh for the internal components of the stock 700R4.
What I'd like to know is, I presume you wanted firmer shifts so you installed a shift kit, now you want to tone it down? I don't really see the logic there. Why didn't you just leave the tranny alone in the first place? Not trying to be rude, just curious.
Old Dec 22, 2000 | 03:02 PM
82z's Avatar
82z
Did you do anything to the pressure regulator or boost valves at all when you installed the kit. If so high line pressure could be causing your problem. If you removed any accumulator springs that would also contribute to harsh shifting. Many shift programming kits include stiffer springs in lieu of total removal. So basically what did you put into/take out or modify in your tranny? Also there is a transmission forum on this site.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Dec 22, 2000 | 03:09 PM
CamaroZ_85's Avatar
go to the tranny forum and im sure dana from pro-built will respond to you...and give you some very good info. if he doesnt reply, find out how to contact him he is very helpful
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
