want to change accesory bracket setup, possible to make water pump spin opposite way?
Old Dec 22, 2000 | 02:01 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
my car has the serpentine setup, but i want to get rid of the passenger side bracket (the one with the smog pump, a/c and the belt tensioner).
to do this, all i have to do is get a smaller belt, and run it the opposite way on the water pump. but...i have a brand new (well like 3k miles on it) edelbrock water pump, and i really dont want to get rid of it(it was kinda expensive). is there any possible way to make it go the other way?
now, it is a "reverse rotation" pump, so i guess i need a regular rotation, which i odnt think they make in the newer serpentine style.
can i just get a new impeller or whatever the hell it is? anyone have any ideas? or does anyone know of a place to get aftermarket belt setups? thanks a lot.
-brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Accel Cap and Rotor, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
[This message has been edited by Z28 Boy (edited December 22, 2000).]
Old Dec 22, 2000 | 09:34 AM
Guest
Guest
Posts: n/a
Getting an impeller is going to be really fun, thats one of those parts that you wont see anywhere.
Most of the time the bearing gets damaged taking the old impeller off, and you have to have a press to do it.
I cant remember what the clearance is like, but maybe you can run it along the water pump and then to the alternator and get away with it. Another thing is that there is no adjustment on a serpentine setup, so getting a belt on there and keeping it tight is going to be fun as well.
Old Dec 22, 2000 | 02:51 PM
82z's Avatar
82z
See if you can get some sort of a/c delete pulley to preserve the factory belt routing and keep headaches to a minimum.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Dec 22, 2000 | 03:22 PM
ede's Avatar
ede
aren't lt1 water pumps reverse flow? seems i heard that once.
ICON Motorsports
1st & 3rd
Terrell351
Jun 13, 2021 01:13 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
