How to get rid of A/C?
Old Dec 22, 2000 | 12:35 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
I would like to remove A/c since i never use it. I have t-tops and i live in the area where the temp rarely goes above +15c in summer time. Winters are long and cold.
Anyway, how do i get rid of this stuff? IS is hard to do and can somebody tell me in point for what to remove?
Will that cause any problems with the computer?
Thanks.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Flowtech Headers 1 1/2, Hooker Y-Pipe 2 1/2, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, MAF Screens/Fins removed, K&N, Gutted Air Boxes, AFPR @45 psi, Ram Air, Throttle Body By-pass, Bumped Timing @12, Bosch +4, MSD 8mm wires, HP Rotor, Cap and Fuel Filter, Sensi Trac rear Shocks.
Old Dec 22, 2000 | 01:45 AM
JPrevost's Avatar
Car: 91 Red Sled
This is a good question. What I've heard and seen is to just rip everything out and cover the ends of all the wires. There is an idle pulley that goes in place of the compressor. The computer won't feel any pain since it doesn't have any sensors on it nor does it control any of it. Only thing the computer does and I'm not even sure if it does is control the second fan to turn on when the AC is on. But I think that's hardwired (should be). Really you shouldn't have much trouble with it.
, Jon (91 RS too many mods to list)
Old Dec 22, 2000 | 02:42 PM
Dan87IROC-Z's Avatar
I'd also like some advice about how to do this, I have been considering doing it when I do my cam swap in January
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
Old Dec 22, 2000 | 07:19 PM
scauffiel's Avatar
I did this - all that you have to do is get the AC delete pulley from the dealer then tear all of the junk out. Make sure that the freon is gone before you do this - that stuff can kill. I cut out the condenser (?) from my heater box, then covered up the hole with fiberglass. Cleared up a lot of the clutter in the engine bay - and shaved a couple of pounds as well.
Steve
Steve's Trans Am Temple
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
Zell1luk
Sep 29, 2015 10:36 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
