dumb question
Old Nov 16, 2003 | 09:17 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
dumb question
how do you guys judge when your plugs are tight when you do a tuneup without a torque wrench, ive heard to hand tighten till they are against the head then an extra 1/4 turn. Thanx
Old Nov 16, 2003 | 09:25 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
just snug them up....plain n simple
Old Nov 17, 2003 | 05:42 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
The general system I use to apply torque to a bolt when I'm not using a torque wrench depends on the size of the ratchet.
1/4 in ratchet: One grunt past snug.
3/8 in ratchet: Two grunts past snug.
1/2 in ratchet: Three grunts past snug.
Old Nov 17, 2003 | 05:50 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Depends on what kind of heads you have. Most of the time the rating for plugs is in inch pounds but I don't have the rating. Usually with iron heads just turn about 1/4 past seat. On Aluminum you need to be careful and not overtighten because the threads can be easily damaged.
Old Nov 17, 2003 | 09:21 PM
Vader's Avatar
Lots of variables.
Gasketed plugs get more turn, less torque. Tapered seat plugs get less turn, more torque.
The rules of thumb that I've seen recently are:
Gasketed spark plug - 1/2 turn past contact;
Tapered seat plug in iron heads - 1/8 turn past contact;
Tapered seat plug in aluminum heads - 1/16 turn past contact.
The old specification from the late-'60s and early '70s (when gasketed plugs started to disappear) SBC heads was 15 ft/lb on 14mm tapered seat plugs in iron heads (excecpt fo the SBC 400, which called for 25 ft/lb for some strange reason). Ford listed 15-20 ft/lb for their 18mm tapered seat plugs in iron, 10-15 ftt/lb for 14mm plugs. I don't have torque specs from those days for aluminum heads, since they didn't really exist in stock applications except for a few rare engines. Buick was specifying 20 ft/lb in their aluminum heads.
Hopefully, that should give you some guidelines.
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
