car wont start--no power
Old Nov 17, 2003 | 12:01 AM
strokedtpi's Avatar
Car: 1990 Formula 350
Engine: 5.7
hey guys ive got a friend and his solenoid went bad so he put a new one on and such and it wasnt workin still unless you arched it...well turns out there is SOMETIMES no power to the solenoid...okay heres the crazy part....when you turn the key back to the accessory then start the car everything is fine and there is power there but if you just start it regularly without tryin that it doesnt work. hes had a new steering column recently installed and it is our guess that there is a problem within it. on our cars is there a rod that that moves back and forth when the key is turned that may need adjustment from the recent install of the column..or do we have a completely different problem???
sorry about the length fellas and any help would be cool thanks.
Old Nov 17, 2003 | 12:03 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
VATS.
Old Nov 17, 2003 | 12:05 AM
strokedtpi's Avatar
Engine: 5.7
i dont htink it has VATS actually but i dont think that is the kinda problem tho cause it doesnt jsut work off and on it is very consistent in the pattern it shows but i dunno for sure....are you sayin the key is bad or what?
Old Nov 17, 2003 | 08:53 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
The ignition switch is on top of the column, under the dash, just look for the switch that is the hardest to get to without your third elbow. Prolly just needs a little adjusting, it is held down by two, possibly three, screws, just loosen them up a little, move the switch in the desired direction, tighten them down, and try again. Not real hard, once you figure out how to get your hand in there..... You can usually feel the operating rod, it goes down the left side of the column, and then bends around to the top to hit the switch. Have fun now.
Old Nov 17, 2003 | 09:57 PM
nathan2003's Avatar
Car: Camaro
hey everyone, this is my car that stroked has been talking about, thx stroke for posting for me!
Little update for you all now it just doesn't work at all like how he said if you turn it to ACC then to START and it starts, well now it won't do that either, so I'm assuming that rod is just completely loose now or whatever, im not totally sure if i understand how the rod works
SO Today I just arched the starter to get the car started and I drove it down to the SHOP that put in the steering column and there going to check it out and let me know if thats the problem.... I'll know more tomorrow
BRoss99
Aug 10, 2025 05:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Brcharrelson
Aug 26, 2015 07:47 PM
novaderrik
Aug 10, 2015 12:44 PM
