Determining Damper Size...
Old Nov 17, 2003 | 12:58 PM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
I'm building a new engine. A 355 designed to be run with a blower specifically. I was looking through for a new damper and found multiple sizes. 6 1/4 6 7/8 or 7. Is there really a difference between them, or could any be used. thanks.
Old Nov 17, 2003 | 05:44 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Where are you looking? Most balancers come in 6 3/4" and 8". I guess it wouldn't matter much as long as it cleared and the timing mark was in the right place.
Old Nov 17, 2003 | 07:52 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
I was mainly looking in a jeg magazine. The 8" is external balance, 350s are internal. But still looms the question about both 6 " ones and the 7. Any info will help. Thanks
Old Nov 17, 2003 | 08:00 PM
Vader's Avatar
Geez. I'm almost afraid to be the one to say this, but...
Size doesn't matter. The torsional mass of the inertia ring is what does the dampening. The same effect can be achieved with a smaller diameter asembly if the inertia ring is constructed to have more mass, or even if the hub is loaded with a viscous liquid. The more inherently balanced the engine firing order is arranged, the lower the chance of harmful harmonics. Granted, each power pulse will create some harmonics, but a strong crankshaft and well designed engine will survive with minimal damping effect. Some engines don't even use a key to keep the damper in position. Early Chevys didn't use a bolt, either.
The more significant factor for most lower RPM (under 8,000) engines is whether the crank is balanced internally or not. An externally balanced setup may require a different damper as well as flywheel.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
F-body-fan
Sep 23, 2015 06:36 AM
bubbaz28
Sep 18, 2015 02:09 PM
LiquidBlue
Sep 13, 2015 02:24 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
