GM part numbers
Old Nov 18, 2003 | 02:12 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
GM part numbers
i started writing down the GM part numbers i needed... then i figured, eh, im doing a search and finding them, and then the next guy has to do several searches for the same part numbers...
so heres the idea..... you have a COMMON part and part number, or a part number to somthing i dont have the number for, post it, and we'll make a list.. once theres a decinet amount of things on the list, i'll make it look all nice and pretty in a table and post it online.... may even get it in the tech section on the front page or somthing....
Code:
Part					Part Number
Bowtie Grill				10139545
Camaro Grill
TPI distrib Cover - Plastic		14083696
Screws for Plastic(3X)			14083852
TPI distrib Cover - Aluminum		10108425
Screws for aluminum(3X)			14082425
hood louvers
hood blisters
fasteners for hood louvers (10pack)	11502553
cast Chevorlet valve covers
same covers no logo
same covers pontiac logo
FORD HD brake fluid
not too large of a list, but im just starting....
Old Nov 18, 2003 | 08:01 PM
85TransAm406's Avatar
Car: 1985 Trans Am
pontiac cast covers 10093393
Old Nov 19, 2003 | 08:03 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Baffled Fuel tank( aka 1LE): 10121026
1LE Fuel sender unit (longer): 25094804
1LE Fuel strainer (double screen): 25121120
1LE Fuel Pump: 25116163 --note: shows as valid, but was superceded by a later more generic pump. walbro is proby a better and cheaper choice
Old Jun 5, 2004 | 09:07 PM
Spdfrk1990's Avatar
Ok i searched looking for this 1 question say you have a 91 z28 is the only diff the strainer and the sending unit? Is the pump the same, could you just buy the strainer and the sending unit.If you look them up at gm parts direct nothing comes up .
Old Jun 5, 2004 | 09:49 PM
25THRSS's Avatar
I think this is a great idea!!! For my 92 RS:
10055724 engine oil level indicator tube
10120071 upper radiator hose.
22040195 upper and lower radiator shroud kit
10120070 lower radiator hose
22063426 washer tank
10170175 coolant resiover
Old Jun 5, 2004 | 10:00 PM
Spdfrk1990's Avatar
Hmm when u put the coolant number into the GMpart site u get hood latch hardware and the washer bottle comes up as the radiator overflow.Anyone have the partnumber for the oil cooler.
Old Jun 5, 2004 | 10:06 PM
25THRSS's Avatar
fixed
Old Jun 6, 2004 | 01:31 AM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
For what it's worth... Off a 1991 Trans Am with the 15 inch folding spare tire...
Stowaway Spare Tire Inflator - 9590679
That's the tall can.
Old Jun 6, 2004 | 01:36 AM
25THRSS's Avatar
I think this needs to be made a sticky
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
