Rear disc brakes seem to be sticking.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
When I slow down or or start to roll my rear brakes will make a moaning sound. Sounds like they are sticking. Also, my E-brake needs to come almost vertical to keep the car still when I park the car.
If I need to change the rear pads, will it be the same as doing the front ones?
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Zepher
WS6 Trans Am
Car: '89 GTA
Engine: ZZ6TPI
The rear pads are pretty much that same, except you will need a tool to compress the piston back. It needs to be screwed back in, not just pushed in like the fronts. While you have it apart, check you cables, and lube the mounting bolts, and bleed the system.
89 Transam GTA, a few bolt ons
Zepher,
Don't forget to clean and lube the park brake actuating screws. The recommended lubricant is clean brake fluid. Make sure the levers are operating freely, and the return springs are not broken from corrosion. Replacement springs are available, but you'll have to go to a real auto parts house to get them. The replacements should be a little stiffer, since the GM recall on these brakes included a stiffer spring as the solution.
It would also help to clean the park brake cables and lightly lube them with Lubriplate or some other white lithium grease.
In a nutshell, if you want your brakes to be fully functional and not stick, plan to spend some time on these rear calipers.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Later,
Vader
Thanks.
You guys are a great resource.
I'd be lost without this site.
And Happy Holidays to everyone.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
