How Do I Get To My Fuel Pump???
Old Dec 24, 2000 | 02:21 PM
nesluopetan's Avatar
Ive got an 82 Z28 and just found out my fuel pump is shot. Do I have to go underneath and drop the gas tank? where is it exactly? or is there a way to access it from my hatchback area? can i buy a better fuel pump that will give me more horsepower or are they all the same? i need this changed soon so please tell me the steps i need to do in order to change it, thanks again guys
Nate
Old Dec 24, 2000 | 03:51 PM
ede's Avatar
ede
yep it's in the gas tank, you have to drop the rear and the exhaulst to get the tank out.
ICON Motorsports
1st & 3rd
Old Dec 24, 2000 | 03:55 PM
CamaroMike's Avatar
WHOA HOLD ON! Ede it's an 82 Camaro! The fuel pump is on the passenger side of the engine block unless it's CrossFire. I don't know where the Crossfire pumps are but he could have an L69 which has the fuel pump on the engine block.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Dec 24, 2000 | 04:26 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
His earlier post stated its a crossfire.
In the tank we go!!
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Dec 24, 2000 | 05:00 PM
CamaroMike's Avatar
Good luck with that pump. Man I hate tank pumps!
Old Dec 24, 2000 | 07:08 PM
MikeC.86Roc's Avatar
I just pulled the gas tank and pump on my 88 Iroc last nite. I am installing a 255ltr per hr. Walbro pump. I don't know how much pressure you need for a crossfire setup, but I bet Auto performance engineering can help you. I paid 98$ shipped for my pump which is ALOT cheaper then all the other places I checked. The number there is (877)875-2091 toll free. The people are great to deal with and very knowledgable. I would recomend completely pulling the rear axle and the exhaust from behind the cat, it will make things much easier and you will not bend/damage things trying to remove the tank. Also be careful not to break the tack welds on the metal pump support. That stuff is delicate and you can cause some costly repairs if you dont take your time while removing the pump assembly!
Old Dec 24, 2000 | 07:52 PM
Dan87IROC-Z's Avatar
If its a carbed engine, it should be on the lower right side of block, and its not too hard to replace so long as you can get under the car.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
