New distributer or not?
Old Dec 23, 2000 | 05:25 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Ok here is the deal my car die a few weeks ago, and found the pick up coil is corroded beyond belief. I got the new coil for $8, since I have to pull the ditrib any way should I replace it, if so which replacement?
87 Z28 305 TPI, Auto, 2.77, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 160 Stat.
Best 15.414 @ 87.47, 3.23 and SLP airfoil on the way!
Old Dec 23, 2000 | 05:58 PM
Blade's Avatar
MSD !
Old Dec 24, 2000 | 02:01 PM
ede's Avatar
ede
if yours isn't bad why change it? if you do i'd look at msd parts first. i doubt if you'll feel much if any preformance gain from the distributor swap alone.
ICON Motorsports
1st & 3rd
Old Dec 24, 2000 | 02:13 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Ok I had to pull the hole upper intake off the get to the Distrubuter nut. Did I do something wrong?
Old Dec 24, 2000 | 03:53 PM
ede's Avatar
ede
yeah i'd say you did, but i'm not sure what. it's usually pretty easy to get at with common tools and real easy with a distributor wrench.
ICON Motorsports
1st & 3rd
Old Dec 24, 2000 | 06:43 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
Ok I had a distrib wrench and I keep hiting the full rails. So tonite I removed everything to the Intake manifold. So its out now and I put the new pick up coil in. When I pt it back together there are two retaining clips a circle and a square which should I use?
Old Dec 24, 2000 | 07:15 PM
MikeC.86Roc's Avatar
use the same piece that came off the old one or similar to it?? and good luck to you!!
Old Dec 25, 2000 | 10:33 AM
Pat Hall's Avatar
OMG dude, you must be a glutton for self punishment! A little more patience trying to get that bolt loose would make your life a lot easier!
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Dec 25, 2000 | 12:06 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
The fuel rails to! But I need it to do it any way O'well chalk it up to expirence.
db057
Apr 28, 2019 07:45 AM
Gunner242
Dec 25, 2015 04:49 PM
drptop70ss
Oct 4, 2015 09:44 PM
dusterbd
Sep 29, 2015 08:40 AM
pimprs
Aug 24, 2015 11:20 PM
