oil overfull
Old Nov 21, 2003 | 07:44 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
oil overfull
How big of a deal is it if the oil is overfull by a 1/4" on the dip stick?
Old Nov 21, 2003 | 07:48 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Like 1/4 of a quart over the full line? No problem.
1/4 of the dipstick, you might have some problems.
If it's 1/4 of the dipstick, just drain off some from the pan, check level, repeat until desired level is reached.
Old Nov 21, 2003 | 05:14 PM
Vader's Avatar
Or you could remove the oil filter, drain it, and reinstall it rather than trying to guess by removing the oil drain plug.
Old Nov 21, 2003 | 10:23 PM
kfoley's Avatar
Car: '85 Z28
True, that would be easier...
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Numbah-1
Oct 2, 2015 08:27 AM
meeklay812
Oct 1, 2015 03:46 PM
