Flywheel interchangeablity ?'s
Old Nov 21, 2003 | 05:50 PM
87LT's Avatar
Car: 1987 Camaro LT
Engine: modifide 2.8L
Transmission: 5 speed
Hey Guys,
I want to take the T5 out of an 87 IROC and put it behind a 283 SBC. I'm pretty sure the trans will physicly bolt up considering it is replacing a TH350. So here is my question... does any one know if the flywheel for the 305 in the Iroc will work on the '67 283? If not, I'm going to have to find one that will, and then am I going to have to come up with some crazy clutch config to make everthing work?
This may sound all like stupid questions but I'm pretty new at this parts swapping stuff but I'll be greatfull for any info
Old Nov 21, 2003 | 06:04 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Flywheel
No it won't fit. You will need a flywheel for a two piece rear seal crank that is 153 tooth. The clutch from the '87 will fit that wheel.
Old Nov 21, 2003 | 07:54 PM
PhilM's Avatar
Car: Accepting applications...
Yep, like he said the 153 tooth two piece. I had a rough time finding a good used one.
Way to go with the 283, I love it when people dare to be different. I am sure a lot of people will say you are nuts, but I like the idea...
Old Nov 21, 2003 | 11:32 PM
radiateu2's Avatar
try here for the flywheel. You will have to call them though www.enginekits.com
Old Nov 22, 2003 | 09:52 PM
87LT's Avatar
Car: 1987 Camaro LT
Thanks for the info.. it's exactly what I needed to know. I found one of those flywheels in the P.A.W catalog for about $200, but I will try a few other places aswell.
As for the 283, yes it is differant and I like that. Plus it fits with the period of the car. Why scrap a perfectly good engine just to be like everyone else? I'm just looking forward to shifting my own gears.. and highway cruizin' in overdrive
Thanks again for the help!
Old Nov 22, 2003 | 11:06 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
GAH!!!! 200$??!??!??!
NAPA!!!!
50 dollars with a core, 100 bucks without, ask for a flywheel from an '82 Z28.
save yourself atleast 100 bucks
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
