distributor help / pickup coil?
Old Nov 22, 2003 | 11:42 AM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
I'm getting spark from my coil to the distributor, but not getting any to the plugs. I replaced the coil this morning with a brand new MSD Blaster coil, a new cap, and new rotor. The spring in the old cap rattled and the new one didn't, so I figured that was my problem. I've replaced the ignition module on Thursday and tested the pickup coil while I was in there. The pickup coil tests fine. I also replaced the ESC about six months ago.
Could it be that the pickup coil's testing fine but not putting out enough to get the car started?
Old Nov 22, 2003 | 11:49 AM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
yup!it sure can....replace the pick up coil,our factory dist. are in need of upgrades by now if not just be replaced....
Old Nov 22, 2003 | 02:15 PM
redrummer's Avatar
Engine: 5.7L L98
Well, nevermind. It's not the pickup coil. What else could it be? I'm at a loss.
Old Nov 22, 2003 | 03:09 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
possibly the lil circuit board underneath the cap... doubftfully though...
how did u rule out the pick-up coil? your testing method may be wrong...
aint much about an ignition system....your new igniton module may be bad ( i know its new, i bought a new coil and it ended up being bad, led me tearing down wires for 3 weeks, tore my truck up cause of it)
Try snatching one from someones car that you know works, rule it out for good (the tests they perform on them can show they are good but still not be)
try these thigns first
Old Nov 22, 2003 | 08:22 PM
redrummer's Avatar
Engine: 5.7L L98
Circuit board under the cap? I assume you're talking about a coil-in-cap distributor? I've got a remote coil.
I've replaced the new ignition module with the old one already and getting the same thing.
The pickup coil is ruled out because I replaced it with a new one.
I'm getting spark at the plugs now. I've got good fuel pressure. I'm starting to wonder if maybe my injectors aren't pulsing.
The coil I replaced with the MSD definitely was bad though. I wasn't getting hardly any spark out of it.
Edit that...
I'm not getting spark at the plugs. It's firing every now and then at the plugs. I hooked up the timing light to the coil wire and it lights up, no problem. I'm not getting any light flash whatsoever at any of the plug wires.
I've replaced...
coil
pickup coil
rotor
cap
ignition module
esc (6 months ago)
What am I missing here?
Old Nov 23, 2003 | 02:56 AM
gen3z's Avatar
if you are getting spark from the coil to the cap but not to the wires your cap has a problem,i hope i read your statement correctly....is the contact still on the rotor,something here is being overlooked.
Old Nov 24, 2003 | 07:02 PM
redrummer's Avatar
Engine: 5.7L L98
Everything's new.
Old Nov 24, 2003 | 08:06 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
just cause its new doesnt mean its functional..
if u get a spark every now n then, i would assume your caps points are messed up or your pick-up coil (regardless of how new it is) is bad..
for an example, i bought a brand new coil and it was bad... led me on a wild goose chase cause
a. I had the attitude u had, its new it MSUT work
b. they told me for sure they knew the coil was good, when in fact it wasnt.
there is a way to test the pick-up coil without removing the distrib, i dont remember how i did mine in my truck, i think i traced the wire and i think it had to pump out between .5 -1.5 volts....
i could be wrong but do some research/call n ask around..
Old Nov 24, 2003 | 09:02 PM
redrummer's Avatar
Engine: 5.7L L98
I'm still toying with it during my breaks from building the new motor.
I've tested the pickup coil, continuity through every line I can find, used two different ignition modules, etc. Everything I've tested tests out fine.
The only thing I haven't tested is the ESC. Is there anyway to test that? I can't afford to shell out another $70 to buy another one and it not be the problem.
Old Nov 25, 2003 | 04:23 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
from what i heard theres no way to test it, just replace it and see if it fixes it...
I hope i'm proven wrong for your sake, but i dont think theres a way to test them.
MM2Robinson
Oct 1, 2017 09:16 AM
djmarch
May 8, 2016 11:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
Jlanz55
Sep 6, 2015 03:05 PM
