Bolt sheared off
Old Dec 27, 2000 | 10:27 AM
Blade's Avatar
Bolt sheared off
In the flange of my Edelbrcok driver's side header. LOL It sticks out about 2 inches. Any tip to get it out ? I tried the double nut idea, vicegrips and that's about it. Any other ways to get that sucka out w/out using a torch or cutting off then drill it ? THanx
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Dec 27, 2000 | 05:33 PM
ede's Avatar
ede
not sure i fully understand what you're trying to say, but if there is enough bolt sticking out to get vice grips on try a pipe wrench. maybe weld a nut on the stub and use a wrench, plus the heat will help break things loose. good luck broken bolts suck about as much as stripped threads.
ICON Motorsports
1st & 3rd
Old Dec 27, 2000 | 06:04 PM
Vader's Avatar
ChanNelLock 410G pliers will remove it. Don't use "regular" water pump pliers or Peterson Vise-Grips - they won't grab the bolt anywhere near as well as the 410s. I've actually won bets using these pliers on "stuck" bolts and parts. If it can grip it, you will either get it out or break it more.
As a last resort, get out the center punch, drill, and tap. Exhaust flange bolts are not super critical for location, so a few thou one way or another is no big deal.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 27, 2000 | 06:49 PM
Blade's Avatar
Thanx Vader... Do they sell those at local auto parts stores ?
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
