For people who say you cant remove heads with studs in a car..
Old Nov 23, 2003 | 10:32 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Why dont you spend the extra 15 minutes per head and remove the studs as well? The studs do that an allen head on the top to remove them
Old Nov 24, 2003 | 12:34 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
http://www.electronic-pr.com/pr/new_arp_741.html
Old Nov 24, 2003 | 01:17 AM
radiateu2's Avatar
In my opinion, why have the studs if you have to remove them any way to remove the head. Kinda defeats the purpose, doesnt it?
Old Nov 24, 2003 | 08:01 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you REALLY want to get into it, disconnect the exhaust, watch the lines, pull ONE engine mount bolt, tilt the entire motor enough that you can lift one head up and out...
then do the same for the other side...
havent tried it, but it could work...
back in a auto shop class, we had a guy snap off a headbolt into the block.... it was the lower drivers side small one...
so of course you cant get at it... brake booster and all.... i had to drill and easy out it.... i ended up tilting the entire friggin engine that way until i could put a drill straight on the bolt... heh...
im probly going to use studs on my new motor.
hopefully i wont pull the heads off often enough to care.
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
355tpipickup
Aug 25, 2015 12:54 AM
3rdgenparts
Aug 8, 2015 07:09 PM
