Need help quick!!! What is the timing on '86 Camaro 2.8 FI???
Old Dec 27, 2000 | 08:58 PM
R.O.B.'s Avatar
I'm working on my buddy's Camaro right now because it failed emissions. Over on the HC's and CO's. Base timing was 10*, with the computer taking over it was 18*. Plugs, wires, cap/rotor done about 1 month ago, 02 done about 1 year ago.
Is the timing set correctly, (sticker missing from hood), and any ideas to get it to pass emissions?
Rob
'86 TA 305 TPI
Old Dec 27, 2000 | 11:00 PM
squirrels's Avatar
I've got the Chilton here...the 2.8L 6 cyl (VIN S) for 1986 is 10 degrees before TDC. Also you might need to ground terminals A and B in the ALDL diagnostic connector to make sure the ECM doesn't advance the timing while you're setting it.
Mark
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
86Base
Aug 8, 2015 01:34 PM
