Fan Belt Routing Idea, Please Help
Car: trans am 1991
I would like to remove the emissions air pump right under my A,C compressore for a cleaner look. Now, the last time I tried this, every one who replied focused on the cat, and all they would write about was how the cat was going to clog up over time. The cat has been removed and all the air lines tothe cat and exaust manifolds. I have headers now, so the engine lookes clean except for that pump that makes a loud grinding sound. I have a 1991 Trans Am Formula. Itseems that the air pump pulley is reslly needed in the routing, so here are my quetions. here is a pic of the oem set up. Will this other way work? How do I get a shorter custom belt?
Let meknow if you have anyideas, thanks
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
