1977 heads on a 1986
hello all:
I have a set of heads from "I think" a 77 305 nova. can I use them on a 1986 305 trans am. The numbers on the old heads are 378450.
Im getting ready to rebuild, if I can do the work on the 77heads it will be a quicker turnaround when I pull the engine out of the trans am.
parts I have so far for the rebuild are:
Comp Cams double roller, Magnum timing set.
Edelbrock Performer non-egr intake.
Comp Cams Extreme Energy 256.
Comp Cams 1.60 ratio, Magnum roller tip rockers.
Comp Cams High Energy, hydraulic, lifter set
Parts not purchased.
Melling M-55 oil pump, shaft, screen and Mr G spring.
SLP single cat Headers "for what engine should these be?"
Chevrolet: 262-400, conical valve spring kit
Hypertech 160 degree, cool fan switch.
please give me a lashing if I have anything to stupid. but don't bring up the "why don't you rebuild a 350"
I an't paying no monster no 350.
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
When u do up a 305... what u get..... a mild 350.
Sorrry had too.
The heads will fit. Not much more worth saying about them.
Sorrry had too.
Thanks for the info!
This is a Dyno2000 of the before/after rebuild. The engine is in bad shape now with 140k on it. I will get a BIG improvement for little cash and keep my 20 miles to the gallon. All I’m looking for is a good working motor with a little more juice than it had before
Are there any differences in the heads that will affect performance? I plan to do porting and change the rod holes to accept the 1.6 rockers.
Chuck
Chuck
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
those 77 smogger heads are garbage. The combustion chambers are so big that you'll lose a ton of compression, and they don't flow. Keep your 86 heads. They don't flow too good either, but it's a lot better than those 77 heads, plus it'll keep your compression up.
376450.....75-81...262/267/305..6 or 7 exhaust bolt holes, 60cc chamber
Chambers are 2 cc bigger and I think these are a casting thats worth some porting. I know of one guy that has a set on a strong running 327.
Anyone else look at his dyno #'s there?
Your car does NOT have 220hp and 320tq stock, with an LG4 sorry. Try 165hp and around 250tq. The LB9's didnt even have that much power in 86.
86 IROC-Z
Trans Am A4 LB9 V8 9.5:1 5.0 (305) 190@4000 285@2800 TPI ---- ---- 2.73 3.42
DD is way wrong on anything unless u get every little detail on it correct.
86 IROC-Z
Trans Am M5,A4 LG4 V8 9.5:1 5.0 (305) 165@4400 250@2000 4bbl 3.23 3.73 2.73
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Your gunna want different pistons in there to up the compresion if u want any power out of that thing.
Cams a good choice though, XE cams make very good power.
86 IROC-Z
86 IROC-Z
Transmission: 4L80E/4L80E
Forget the old heads. The ones you have now are much better. With 1.94" intake valves and basic porting, they will out-run those old heads no matter what you do with them.
You should consider pinning the rocker studs, or replacing them with screw-in. Just for insurance.
I really like my cam. But, I don't have any personal experience with the Comps.
You have flat-top pistons now, so you're okay there.
Wrong intake manifold. Get a Weiand Action+ EGR or GMPP spread-bore EGR.
Headers should be for '86-'90 TPI single-cat application. I'd suggest Hooker over SLP for cost reasons, if nothing else. Cat & cat-back for same application to finish it off.
ambainb
Apr 25, 2016 09:21 PM
Pilotrick50
Sep 2, 2015 12:48 PM
