Oil pumps.....
Old Nov 25, 2003 | 08:32 PM
BIRD91ZRAG's Avatar
Oil pumps.....
Did a search, but to no avail...
What is the recommended oil pump for a 406 that will be limited to 6000 rpm, and has a fresh bottom end?
Hi Volume, Hi Pressure, or just a standard M55????
Thanks!
Old Nov 25, 2003 | 08:45 PM
Kitch's Avatar
I like the Hi Volume with the low pressure spring in it. But there's nothing wrong with a standard pump if your'e running tight bearing clearances.
Old Nov 25, 2003 | 08:49 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
a standard volume M55 with the mr gasket #26 High pressure spring.
Old Nov 25, 2003 | 08:54 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
That's my setup also (ACTUALLY, it's a M55 pump body, a GM top half (pickup tube wouldn't fit anything else), and the Mr. Gasket spring).
Not a bad deal at all since the pump's $15.99, and the Spring's $3.99.
Old Nov 26, 2003 | 04:44 AM
ede's Avatar
ede
all i've ever used is a m55 with the mr gasket spring, weld a brace from the pick up and bolt to the pump body
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
