Fuel problem i think
Old Nov 25, 2003 | 09:57 PM
RyanPoser's Avatar
Car: 92 z28
Transmission: 5 speed
Ok somtimes when I'm driving my car at a steady rpm it will go wacky the rpm gauge that is plus i do fill it in the engine. At first I thought this might be the fuel filter or somthing to do with the fuel system, fuel pump or MAF. The RPM guage will bounce a little up and down. I just replaced the fuel filter so next i guess I will clean the injecters and replace the fuel pump or MAF. Any help would be great.
Oh yah its a 92 z28 5.0 TPI stock
Old Nov 25, 2003 | 10:48 PM
RyanPoser's Avatar
Car: 92 z28
I took it to the only mechanic out here and they ran a test on it and it came up clean. Everyone suggests fuel filter but I already replaced it.
Old Nov 26, 2003 | 04:59 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, you don't have a MAF, so you can rule that out
Does the SES light come on?
Have you checked for codes?
Given it a tuneup lately? (cap/rotor/plugs)
Old Nov 26, 2003 | 05:55 PM
RyanPoser's Avatar
Car: 92 z28
Well I just got new plugs and fuel filter I might have mistaken the MAF with ECM. I really dont know how to get codes but It might be electrical after reading some other threads about similiar problems.
Old Nov 26, 2003 | 06:54 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
theres an article in the Tech articles on the homepage of
thirdgen.org
that tells u the codes and how to get them.. that is, if the SES light is on..
did u put the fuel filter on correctly? if u put it on backwards fuel wont flow properly.
Did the mechanic test the fuel pressure? the injectors may be dirty as well..
some other things to ponder upon..
Old Nov 26, 2003 | 10:34 PM
CSAR Gunner's Avatar
Car: 1972 442 convertible, 1992 RS with L03
Transmission: 442 has T56, RS has 700R4
I had the same type of problem and after beating my head on the
dash a couple times I found that the rubber hose from the fuel pump to the metal line inside the tank had a hole in it. The only reason that I found that is because I was changing the fuel pump thinking that was the problem. After that the car is runnig great.
Old Nov 26, 2003 | 10:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
thirdgen.org
I can second all that.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
