Fuel Pump help
Old Nov 26, 2003 | 12:19 PM
Kaas's Avatar
Car: 89 Iroc-Z
Fuel Pump help
Heya, was wondering if anyone had any secrets in how to change the fuel pump without having to drop the exhaust and rear and such, plz leave a line if you can help
Old Nov 26, 2003 | 02:45 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
The only other access would be through the trunk. If you have a junkyard nearby, maybe you can practice by cutting the trunk off the same car, this way you will know where exactly to do the cut on your car. Extreme caution should be used when cutting since you may have fumes from the gas present. Hope this helps.
Old Nov 26, 2003 | 02:46 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Fuel Pump help
Pull up the carpet in the back luggage area.
Cut an access hole(door flap) in the rear compartment right over the fuel tank. Look under the car to see where the fuel lines go to the tank so you'll see where the tank pickup is located.
When your done, bend the flap of metal back down and attach with some sheet metal screws and small taps of sheet metal. then, seam seal up the gaps.
Old Nov 26, 2003 | 05:12 PM
deadtrend1's Avatar
Oh man, this isnt going to go over too well. I was flamed hardcore for cutting the hole a long time ago ....
Old Nov 26, 2003 | 05:37 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i am about to undergo the same peoject, there is no way i am going to cut a hole in MY car, sounds like a stupid (and possibly dangerouse idea) no wonder somone would get flamed for doing that.
deadtrend1, not saying you are dumb or anything, i mean your still alive so you must not have done anything to bad. just not planning to do that myself.
Kass, i would just suck it up and do it the hard way like i am planning to do.
by the way, you can get a new fuel pump for 70.33 at GMPARTSDIRECT.com that includes shipping! gm charges 117.22
part number is 25116162.
and there seems to be some debate as to weather or not you neede to get the "pulsator" with that. see the POLL on the subject by clicking the word poll. i am trying to get input on that but no one is biting.
Old Nov 26, 2003 | 06:21 PM
llvll4l2c91350's Avatar
https://www.thirdgen.org/techbb2/sho...ight=fuel+pump
i would also suggest against cutting a hole.
it's not as hard as it seems. make sure you empty as much of it as possible for obvious reasons. and also try to have someone around to help you lift it when it's time to put it back in.
and here's a dumb q,,,,what is the pulsator??
Old Dec 11, 2003 | 03:03 PM
kahamri's Avatar
Car: Camaro
Engine: More than one
Transmission: More than one
It's not as bad as it sounds, we did this not to long ago...It makes a nice access pannel..But if you have no idea what your doing..no, i wouldnt do it.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
