what weight oil do you use in a 400 hp 350 small block
Old Nov 27, 2003 | 11:42 AM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
thnks I live in jersey and its getting cold its a 355 500miles on it so far thnks
Old Nov 27, 2003 | 11:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Same as you'd use in any other motor with similarly normal power output...
I'd recommend 10W-30 high quality full synthetic such as Mobil1, Amsoil, RedLine, Royal Purple, etc.; maybe Valvoline; not Castrol or Pennzoil.
Old Nov 27, 2003 | 04:19 PM
25THRSS's Avatar
Go as thin as you can IMO. Thicker oil just robs you of hp.
Old Nov 27, 2003 | 08:11 PM
SHAGME's Avatar
Car: 1988 IROC-Z
ok thnks guys appriciate it happy TURKEY DAY GOBBLE GOBBLE
Old Nov 27, 2003 | 11:06 PM
breathment's Avatar
i know you highly recomend Amsoil.. and i understand all your other recomendations except for NOT using Pennzoil. I thought i remember seeing some test that said the Pennzoil Synthetic was just below Mobil 1? its been a while but im just curious because i like to have all the information i can about this sorta stuff. and im not trying to start a "wich oil is better" thread. im only concerned with pennzoil. i dont even use it (i use mobil 1) but like i said im jsut curious here.
jhawkeye
May 25, 2022 06:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
