Vacuum lines near coil on tpi?
Old Dec 30, 2000 | 01:55 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Does anyone know offhand the exact routing of the two vacuum lines that come from the fitting underneath the coil bracked? I ran one to the egr valve and the other to the front of the tb. Is this correct? Thanks a lot.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Dec 30, 2000 | 02:36 PM
Vader's Avatar
U ROCK,
That should be the EGR solenoid. One line goes to the EGR, the other to the timed vacuum source on the underside of the TB. The port that connects the EGR also gets vented to atmosphere when the solenoid shifts closed, so the position of the hoses matters. As long as you have the correct hose on the source port, there should be no vacuum leaks and sticking-open EGRs.
It sounds like you have the connections right.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 30, 2000 | 03:49 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Thanks for the help - I'm on my way to the parts store solenoid and hoses in hand to get some regular hose for this thing.
mdtoren
Aug 16, 2015 05:45 PM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
apie2546
Aug 10, 2015 05:43 PM
