Too much fuel injector cleaner not enough gas??
Old Nov 29, 2003 | 02:33 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
I was wondering if you put two bottles of Fuel injector cleaner (1- Lucas Fuel system treatment, 1 - Valvoline Maxlife Injector cleaner) and only about 6 gallons of gas in a tank would it make alot of smoke come out the exhaust?? I put some in my old 4WD and it hadnt been started in about 2 years and man does it put out the smoke, it doesnt stink or anything its just smoke like when you go outside on a cold day and breathe hard. If you hold your hand next the to tailpipe it has alot of moisture in it cause it makes your hand wet.
Old Nov 29, 2003 | 02:41 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
the steam is a caused by the alcahol burning that is in the injector cleaner. it should be fine. just run it as close to dry as you can then put more gas in.
Old Nov 29, 2003 | 06:26 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
I was hoping it wasnt a cracked block or something but it runs fine and smooth as a top.
Old Aug 23, 2012 | 11:22 PM
RRUHL's Avatar
Car: 92 RS
Engine: 350 5.7 TPI from 91z28
Transmission: 700R4 transgo shift kit
Axle/Gears: 84z28 Disk brake with 3.23s
Re: Too much fuel injector cleaner not enough gas??
i put a botle in 4 gallons 350 tpi cars ddead literraly wont start
bryan623
Mar 22, 2021 06:43 PM
Infested
May 22, 2018 11:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
