Lt1 retrofit
Old Dec 3, 2003 | 04:56 AM
377ciTT's Avatar
Car: 94z28,84 3rdgen no engine,64 vette
Engine: lt1,-,350
Transmission: t56,-,m4
Lt1 retrofit
lt1 blocks are becomming increasingly cheaper, and easier to come by im curently thinking of purchassing one from a local junkyard i frequent (Tacreationsusa.com awesome play if you live in sf a little $$ though) but i was wondering if the plugs on the heads are straight or angled and if they are angled at what degrees are they angled at did couple searches on the web and couldnt find too much thanks in advance
Old Dec 3, 2003 | 10:47 AM
Vader's Avatar
It may depend on the engine you acquire. I know that stock, iron-headed LT1s have straight plugs.
If you get one, make sure you get the exhaust manifolds and EGR supply tube with the engine.
Old Dec 3, 2003 | 10:03 PM
377ciTT's Avatar
Engine: lt1,-,350
:lala: :lala: :lala:
haha yea i think they are angled (alum stock camaro heads) but im not sure i have to pull the heads out of my garage (looks like afganistan after the us bombed it) and look thats for the info but who wants manifolds when you could use headers and if i took the egr off this car would it run even if it spit a code and if it justs spits a code would it run in sd or the other one that uses maf
im using an lt1 out of a 95 ta or z28 or formula
Old Dec 4, 2003 | 01:01 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I don't know if you can tell the angle, but here is a pic of my LT4,
Oh, and the iron LT1 head,
Old Dec 4, 2003 | 06:22 AM
377ciTT's Avatar
Engine: lt1,-,350
looks nice
you are using lt1 heads with an lt4 intake? you had them port matched right? actually this is a whole diffrent topic =) already posted it kinda anyways what are you dropping it in =) hope your not dropping it on that engine stand
Old Dec 4, 2003 | 01:48 PM
Zepher's Avatar
Re: looks nice
No, that LT4 setup was LT4 heads and an LT4 intake.
I put the motor in the car in my sig.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
