just curious on some specs here
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
ok for the SBC need to get a little info here
for cranks what was the journal size for the
350
400
302
283
327
also any other cranks that I didn't mention stroke and journal would be nice
also what was the stroke for the 283
can you fit a 283 crank into a 400 block
what different STANDARD bore's are there.. sorry guys no overbore here and from what block did they come from
350
400
302
283
327
Transmission: 4L80E/4L80E
All of that info is available on www.mortec.com .
http://www.mortec.com/journal.htm
http://www.mortec.com/borstrok.htm
Except the 283 crank in a 400 question. Would need major main bearing spacers.
Better question would be whether there's anything between Vader's ears that isn't known...
