Coil Binding vs. Max Lift Question?
Old Dec 5, 2003 | 09:50 AM
87F383's Avatar
Car: 87 Formula 350
Engine: LS1 in Progress
Axle/Gears: 3.70 9 bolt
How many thousandths of an inch or clearance should my valve springs have at max lift to pevent coil bind. The heads I'm thinking of purchasing are rated to .600" of lift. What is a safe lift I can run? Or what is considered a safe margin or error to prevent coil bind?
Thank you in advance,
Aaron
Old Dec 5, 2003 | 10:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
http://www.compcams.com/Technical/Pr.../ValveSprings/
Old Dec 5, 2003 | 10:43 AM
87F383's Avatar
Car: 87 Formula 350
From that link I got this:
" This means that when the valve is fully open there must be a minimum of .060" clearance between the coils of both the inner and outer springs. "
Does this mean on a head capable of .600" of lift...I should go no higher than .540" to maintain coil distance?
Old Dec 5, 2003 | 11:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Seems reasonable
Fronzizzle
Mar 18, 2019 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
midias
Aug 15, 2015 05:07 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
