Help w/ MSD 6a hookup to a 4-pin HEI needed
Old Dec 29, 2000 | 10:09 AM
Biochem's Avatar
Car: 2002 SOM z28
The directions suck! I was told I needed some special adapter to hook the MSD box up using the magnetic pickup wires and not the red and white wires that I used to use with the 7-pin module.
So I get the special adapter... which consists of a short green and purple wire that has a plastic adapter for the magnetic pickup cables at one end and spade fittings on the other end. What sucks is I paid $7 and waited a week for an adapter that I all ready had because it came with my box!
That still doesn't help me though because as best I can tell, the 2 wires (green and purple) from the MSD are supposed to plug into the 3-wire harness that comes from the base of the 4-pin HEI that I now have.
Which wire in the 3-wire harness does the GREEN wire go to and which one does the PURPLE one go to?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Dec 29, 2000 | 12:27 PM
scauffiel's Avatar
Not sure if you checked already or not, but MSD has instructions for all of their stuff online at their site.
Steve
Old Dec 29, 2000 | 12:57 PM
Biochem's Avatar
Car: 2002 SOM z28
Those are the directions that I am talking about (the same ones they sent with the box).
It just has a line going to the HEI that says magnetic pickup to harness #### and that's it. I have 2 wires comming from the MSD box that are supposed to go into 2 of the 3 wires comming from the HEI base...
Old Dec 31, 2000 | 07:58 AM
Biochem's Avatar
Car: 2002 SOM z28
Anyone?
Old Jan 1, 2001 | 09:32 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I am a bit confused as to what part you are having problems with, but I'kll take a shot. For the four pin module, remove the module itself and replace it with the 8861 harness (comes with 6AL), then with the long 8860 harness (grenn & purple wrapped in black plastic) you connect to the magnetic pick up side of the box. Now you hook up outside, the black from the box goes to the forward pin in the cap. The center pin goes to an engine ground, and tthe rear pin is connected to the orange wire from the box. The red wire from the box is connected to the thick pink wire that was in the cap via the white jumper wire that came with the box. Is that what you needed? If not post again, and I'm sure one of us can help.
"I don't want to be right - I just want to know if I'm right"
-Einstein
Old Jan 1, 2001 | 08:02 PM
Biochem's Avatar
Car: 2002 SOM z28
Now I am the one that is confused! You mean that I actually remove the 4-pin module from my HEI? Toss it? Replace where it connects with the 2-wire harness (#8861) inside the HEI?
After all the modules I've bought (3 so far for various HEIs) and you want me to toss one! LOL!!!!
So yes, where exactly do I plug in the green wire and where exactly do I plug in the purple wire? This all occurs inside the HEI base I guess...
Old Jan 2, 2001 | 12:45 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, you're basically going to use the MSD 6 box as your HEI module. There's two sides of that HEI module, right? One for the spark coil and one for the pickup coil?
So first, you unplug the pick-up coil from one side of the HEI module. Then, you plug in the harness you bought (8861) into the pick-up coil. I don't think it matters which wire goes to what terminal on that pick-up coil, since all the coil's giving off is a magnetic pulse. Know what I mean? Those pickup wires might as well be the same color, there's no positive/negative, or up/down, or left/right "assignment" given to them. As long as they go to the pickup coil, they'll work. Someone check me on this?
You've got the rest, right? (Black/orange, red, and ground?)
You could always call MSD, too- they've got a great tech support.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited January 02, 2001).]
Old Jan 2, 2001 | 09:14 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
<center>Yep.</center>
Don't have the Vette handy, but I think Tom is right, I don't think it mattered where I put what, however, I think the ends are made to fit one way from harness to box.
"Harnessed Evil can indeed be used for Good, however the corruption that inevitably takes place forges a more sinister and chaotic Evil that far outweighs the good intended at inception. Thus are the first steps toward the chasm of the Dark Side."
-Me
Old Jan 3, 2001 | 07:39 AM
Biochem's Avatar
Car: 2002 SOM z28
Thanks guys! I am waiting on an adjustible vacuum canister, so I will look into this over the weekens hopefully.
codeysabatini
Nov 10, 2015 04:07 PM
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
RedLeader289
Sep 23, 2015 06:50 AM
midias
Aug 15, 2015 05:07 PM
