things i notice, why?
Old Dec 7, 2003 | 12:47 AM
icebird_1981's Avatar
this has been drivein me up the wall, when i am at a stop and i floor it (right to the ground) it feels like my car goes slower then it would if i went like 90% to the floor, or gradualy went to the floor. and if i have it to the floor and let off on the gas the car goes faster. y does it do this? its almost like something is trying to catch up, that the only way i could explain it. is this normal? also this might sound really stupid but when i floor it my car does not sound like i am flooring it, only when i drop to second from a roll, when i am almost at 3000rpm and higher were my car seems to make all its power, anything below that for some resion to me dont sound right (like some is trying to catch up)
Old Dec 7, 2003 | 12:54 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I know what you mean exactly. I have had the same exact issue with my Q-jet from day one, but it is much worse now with the 355 in there. Now it falls flat on it's nose. If I figure it out, i'll let ya know! I don't want to put too much time or $$$ into fixing it, as I'm going to EFI when I get all my ducks in a row.
This may be a question more suited to the carb board though.
Sorry I'm not of any help, just wanted to let you know you're not the only one!
Old Dec 7, 2003 | 02:33 AM
377ciTT's Avatar
Car: 94z28,84 3rdgen no engine,64 vette
Engine: lt1,-,350
Transmission: t56,-,m4
tranny slipping i had this issue with my m6 when the clutch was going is your tranny fresh or your ta converter also had it when i had a vacum leak did you check for air leaking anywhere?
Old Dec 7, 2003 | 03:54 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Post on the carb board.
It sounds like you're not getting enough acellerator pump shot.
Old Dec 7, 2003 | 05:58 AM
ede's Avatar
ede
my uninmormed guess is the vacuum signal is going atmosperic or close to it and it takes a second or two for it to recover
Old Dec 7, 2003 | 11:07 AM
JP84Z430HP's Avatar
Car: 84 Z28
I think I will post my problem on the carb board. It seems after re-reading, that my problem is a bit different, but it still may be the same solution????
As for the Vac signal, using a mechanical gauge, it was not going atmospheric. My car will pull hard, then fall off. If I lift to about 75% throttle, then get back to WOT, it pulls hard then falls back off.... I will try the carb board, maybe it will click right away for someone there.....
Old Dec 7, 2003 | 11:30 AM
Vader's Avatar
You may need to tune your secondary throttles by changing the secondary diaphragm return spring.
chazman
Aug 28, 2018 03:25 PM
redmaroz
Apr 25, 2017 07:14 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
chazman
Aug 22, 2015 02:01 PM
Bob88GTA
Aug 18, 2015 03:31 PM
