air induction
Old Dec 7, 2003 | 02:15 AM
377ciTT's Avatar
Car: 94z28,84 3rdgen no engine,64 vette
Engine: lt1,-,350
Transmission: t56,-,m4
air induction
i recall a few years ago reading something about ram on this site. the setup was using ac ducting hose. I was just stumbling around hoe depot at like 6 or 7 this morning and was looking for a way to get rid of my maf to filter hose so then ac ducting came into mind they had 2 kinds semi rigid and non rigid semi rigid looked like it wouldnt seal properly and non rigid (really flexible( looked like i could bolt it andwhere and would rip
any ideas or sugestions?
Old Dec 7, 2003 | 03:37 PM
Vader's Avatar
Any duct with an 80mm I.D. (about 3-1/8") will work, but a wire reinforced flexible fabric duct will be the most durable. Tried and industrial rubber supplier?
Old Dec 7, 2003 | 05:35 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
vader.... i'm sure you've seen the hose ducting that they use on commercial lawn equipment (trac-vacs, etc.) why couldn't you use something like that?
it's made out of a heavy rubber material, and is wire reinforced.
Old Dec 7, 2003 | 06:04 PM
Vader's Avatar
That's thw stuff, but it's used for a lot more than just lawn equipment. It's a rubberized fabric with spiral wire reinforcement. It's comes in sizes from 2½" to at least 10" (the largest I've used/seen). Used for the aforementioned lawn equipment, industrial dust and mist collection, process material transfer, air supply ducting, protective covering as a conduit for cabling/pneumatics, etc.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
