Help choosing a carb
Old Dec 7, 2003 | 01:52 PM
Daemorok's Avatar
This is what my setup is gonna be:
GM 350 LM1
9.2:1 compression after the heads
Protopline iron lightning heads:
180cc intake runners
2.02/1.60 undercut valves
1.6 roller tip rockers
64cc chambers
Cam:
Comp Cam Kit 238
Grind: 262
Lift: .462"/.469" (.493/.500 after 1.6 rockers)
Duration@ .50 218/224
Lobe Separation 110
Intake:
Weiand Stealth 8016
I was thinking a holly 600 or 650 with mechanical secondaries
any thoughts?
Old Dec 7, 2003 | 02:39 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
650dp or maybe a 700.?
Old Dec 7, 2003 | 03:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Holley 6210
Old Dec 7, 2003 | 03:13 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I wouldnt put anything bigger than a 650 on it. Youd be ok with a 600 or a 650.
RedLeader289
May 28, 2019 01:47 PM
bjpotter
Oct 4, 2015 07:48 PM
Vincent135
Sep 28, 2015 10:50 PM
efiguy
Sep 27, 2015 01:30 PM
