Does no SES light mean no codes?
Old Jan 3, 2001 | 11:51 AM
squirrels's Avatar
I was curious about this...if the SES light doesn't come on, does this mean there are no codes stored in the ECM? I've been having trouble with the car lately, but the SES light never comes on. I think my ECM's working cuz the light came on when I disconnected my distributor-ECM harness to time the car.
Will the car store codes and just not turn the SES light on?
Mark
Old Jan 3, 2001 | 11:57 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
the light always comes on when the code is first read. after that it is stored in memory but the light may not stay on. you can have up to 50 codes i believe stored in memory at once - just disconnect the batt to clear them.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Jan 3, 2001 | 09:19 PM
Vader's Avatar
Squirrel,
It is possible to have error codes (DTCs) without setting the SES (MIL) lamp on. Soem codes are considered secondary, or minor, and do not necessarily set the MIL lamp.
IROC is somewhat correct. There is a limit to the stored codes. There is no numerical limit below the number of possible codes, but DTCs will be retained in RAM for the last 50 engine starts.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
GouldyGTR
Aug 21, 2015 10:43 PM
Omega
Aug 10, 2015 12:46 PM
