85 TPI (305) Coolant Temp Sender?
Old Dec 8, 2003 | 08:36 AM
Nicky71's Avatar
Car: 85 IROC-Z, 67 Corvette Coupe
Engine: 5.0L TPI
Transmission: 700-R4
Hello,
My first post here so I aplogize in advance if I'm doing something wrong...
I just got my hands on an 85 IROC-Z with a TPI 305 (VIN code F). The car runs just great, but the temp gauge and oil pressure gauge stay pegged no matter what. I have a new oil pressure sender to swap in to try solving the oil pressure problem, but I cannot locate the coolant temperature sensor on this car. The dealer does not list a part # for a "F" engine code without NB1 on the SPID tag (like my car). So where does the gauge get a signal from? Anybody have this problem before?
Thanks in advance!
Old Dec 8, 2003 | 08:39 AM
ede's Avatar
ede
left head
Old Dec 8, 2003 | 08:51 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
There's a lot of info on this subject in the cooling section, but as ede says on the driver's side of the engine between the front 2 exhaust outlets should be a sender, with a single connection. This is for the temp gauge. There are other temp senders/switches on other bits of the engine for fans etc have a look through the cooling section for loads of detail.
Old Dec 8, 2003 | 12:59 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
another possibility is that the guage itself is physically stuck up there. i have an 85 iroc and this happened to me once where the needle just kindof got wedged up there and i had to take the cover off the guage cluster to push it back down.
Old Dec 17, 2003 | 11:20 AM
Nicky71's Avatar
Engine: 5.0L TPI
Yep, that's it. Hangs up there every time on startup. Will order a new gauge today...
Thanks!
Fast355
Dec 2, 2016 06:33 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
