88' Camaro problems
88' Camaro problems
I have a 1988 Chevy Camaro with a 350 Engine and Throttle body fuel injection.
Recent work done: Rebuilt throttle body, replaced egr valve, replaced IAC, replaced TPS, replaced MAP, replaced plugs and wires, replaced fuel filter,replaced ignition module,and replaced pcv.
Past mods and repairs: replaced fuel pump, replaced alternator, replaced 305 with 350, installed MSD ignition, installed k&n filter, replaced muffler,replaced O2 sensor, replaced rotor and cap, installed superchip.
Two days ago a guy from a chevy dealer hooked up a computer to the car and all he could tell me was that he believed the ECM was bad. I installed a different ECM and the same problems occured. He also said that he was getting readings from the EST.
Problems: When the car is cold, it stalls often until warm, idling is very rough, acceleration is rough, almost doesn't accelerate until you find the right spot in the pedal, once warm the car has a intermittant pulsing idle, jumps from 500rpm to 1500 rpm. SES light comes on every day now. A code 42 and/or 43. I don't know of any loose connections or problems with the EST.
Thanks in advance,
Logician
Thanks in advance,
Logician
is the iac and tps installed and adjusted correctly (if they're adjustable)? is there a ground problem somewhere in the system? and as someone else posted it doesn't hurt to give the ecm a good rap with your hand on occasion.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
92camaroJoe
Aug 13, 2015 06:07 AM
