no heat
Old Dec 9, 2003 | 11:08 AM
SeanTimothy's Avatar
no heat
blows cold air, no heat, what are the possible problems?
all i can think of is the heater core, im sure theres something else though,,
Old Dec 9, 2003 | 11:26 AM
ede's Avatar
ede
no/low coolent, bad t stat, bad heater control valve, clogged heater core, bad control valve inside the car on the dash heater controls, vacuum leak to heater controls
Old Dec 9, 2003 | 08:56 PM
ty, wanted see where all to look before i started poking at it
Old Dec 11, 2003 | 02:11 PM
bonz's Avatar
Car: 89 GTA
My 87 firebird would only heat after you stepped it down. So I bypassed the heater core and now it heats great. There was also a vacuum leak around the control lever but when I would get that to quit leaking then it wouldnt heat at all.
Old Dec 22, 2003 | 08:07 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
how do you get heat with the heter core bypassed?? without the coolant going through the heter core you get NO heat? can you explain this cause now i'm not getting heat and it only gets hot when i step on the gas.. my heter core is new too i replaced it last winter
Old Dec 24, 2003 | 03:39 PM
bonz's Avatar
Car: 89 GTA
Sorry about that I ment I bypassed the heater valve.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
