Angle of the studs for the rocker arms
Old Dec 9, 2003 | 04:14 PM
a73camaro's Avatar
Hey all,
I measured the angle of the studs (relative to the flat part of the heads) and came up with 12°. I will attempt to spot face the bosses and I want to make sure that I got the right angle.
Anybody done this out there?
Old Dec 10, 2003 | 08:12 AM
ede's Avatar
ede
when i do stud bosses i set the boss up level. i sticl a couple of bolts in the intake or exhaust bolt holes and use screw jacks to raise the head till the boss is level and then clamp the head.
Old Dec 12, 2003 | 01:05 PM
a73camaro's Avatar
I'm doing this on a drill press and I have to build a fixture to "level" the bosses. I will also use the drill press to enlarge the boss holes to accept the 7/16" stud fastener and to help in aligning the tap for cutting threads.
I'm sure of the angle I mesured, just looking for a "warm fuzzy" out there.
Old Dec 12, 2003 | 03:48 PM
Vader's Avatar
Actually, the blueprint angle should be 11° 30" 0'.
Old Dec 13, 2003 | 02:11 PM
a73camaro's Avatar
Once again :hail:Vader comes thru!
So I'm off by 1/2°, not too bad considering I used an inclinometer.
I'll build the fixture with a 11.5° angle.
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
