Slipping Balancer? What RPM OEM?
Old Dec 11, 2003 | 02:42 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Probably a dumb question, but when a balancer starts to slip, it will read retarded right?
For instance if it slipped say 10deg.... when I set the timing mark to 6deg BTDC, I would actually be at 4deg ATDC?
Crank spins clockwise (from front viewpoint) so the balancer should slip the other way?
What is an OEM balancer good for RPM wise?
I've spun her to 6300ish a few times.
-Paul
Old Dec 11, 2003 | 03:24 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I'm not really sure which way it would slip since I've never had any experience with that, but I would think you're reasoning is correct.
The stock ones however don't like high rpms. Maddog racing has chrome fluid dampers for $129 shipped, I just got mine this week.
Old Dec 11, 2003 | 05:37 AM
ede's Avatar
ede
not sure on a max rpm but i'd not want to spin a factory piece over 6000 on any sort of regular basis. you can buy oem replacements from jegs for around 60-70 dollars
Old Dec 11, 2003 | 01:42 PM
I've heard some bad things about Fluidampr....
Might be time to get a new one. I've got the large balancer and timing cover with the tab straight up, rather than to the side.
Old Dec 11, 2003 | 02:56 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Depending on where you eventually want to be with the car you may want to consider upgrading to the appropriate SFI spec balancer now rather than having to do it again later.
You ARE planning on 8 sec 1/4 right Paully ;-)
-Schultzy
Old Dec 11, 2003 | 02:58 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
like what?
Old Dec 11, 2003 | 08:40 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Dude theres been a few aftermarket crank companies blaming fluidamper for crank failures. I think Scat is one. I know on one manufacturers website they actually say not to use fluiddampner or they'll void your warranty.
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
