What is the equation to find CR ?
Old Dec 11, 2003 | 02:18 PM
irocfreak's Avatar
Car: 1986 Iroc-z
Engine: Soon to be 350
Transmission: 700junk4
What is the equation to find compression ratio and where does each variable come from?
Old Dec 11, 2003 | 03:15 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Do a web search on "Compression Ratio Calculator", not only will you find plug-in ones, but also the explanation for each detailed item (on nthe better calculators)
Old Dec 11, 2003 | 10:02 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
off the top of my head....
dsp=(1/4)*pi*bore*bore*stroke/60(to converto cc's)
(Displacement cc+head cc+gasket cc+piston cc+deck cc)/(head cc+gasket cc+piston cc+deck cc)
I would try the online calculater it'll save you time and headaches....
ChristinaMarie
Sep 11, 2015 06:28 PM
NiG
Sep 7, 2015 11:25 PM
Street Lethal
Sep 7, 2015 01:09 PM
