LT4/ZZ4 spring kit
Old Dec 11, 2003 | 04:35 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
LT4/ZZ4 spring kit
i was wondering if the LT4/ZZ4 spring kit would work in 041 heads without any machining. they're 1.32" OD.
also, would it be safe to use those springs and a comp XE264HR cam with press in studs for a while?
Old Dec 13, 2003 | 08:40 AM
Vader's Avatar
I've had those springs (12495494) springs, and they do require head machining.
As for the studs and that cam, with any spring that's adequate to the task of controlling a valve on that lobe, you're risking pulling a stud. At a minimum, you should pin the studs. If you're going to do all that drilling and pinning, it's almost as easy to pull the studs and install screw-in repair studs as insurance.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
crzycamaro86
Sep 12, 2015 05:51 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
