Can't Squeal In 2nd!!!
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
ok i need some common power loss problems. i have the 305 tpi which isnt much but i cant even chirp them in second anymore! its pathetic and i wonder if anyone knows some power loss fixes?
thanks,
ben
thanks,
ben
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: GM T56
Re: Can't Squeal In 2nd!!!
thanks,
ben
thanks,
ben
Have you done a full tune-up (plugs, wires, cap, rotor, etc)? Getting any codes? What gears are you running? -Rippin
Car: 1991 Z28
Engine: 383
Re: Re: Can't Squeal In 2nd!!!
well i can burn them all day in first still but as soon as i hit 2nd it kind of bogs down even worse in third and forth is a joke. yea back in march i did new plugs and wires new cap and rotor. i also put a new fuel filter on over the summer. oil was just changed and i even went as far as to buy that crappy octane booster to see if that would help......nope! i am runnin 3.08 gears but before i could get a nice little chirp now nothing
Car: 1991 Z28
Engine: 383
that is what i was thinking. every once in a while when i have the clutch pressed in i get a horrible squealing sound coming from my tranny/clutch area. as soon as i let off the clutch it quits, it doesnt happen all the time though and now it isnt running as fast as it used to.........any ideas?
Car: 1991 Camaro Z28 Clone
Engine: 350 w/TBI
Transmission: WC T-5
Axle/Gears: Spicer 3:73 Auburn Posi
Possibly plugged cat converter? those are a major source of lost power sometimes... just an idea...
Car: 1989 C4
Axle/Gears: 307
A bad through out bearing or pilot bushing/brearing will cause the squealing. As far as power loss and bad cat like mentioned can cause loss of power, need of a tune up or engine wear. If you trying to spin them in second good chance the engine has wear.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I had the same problem, lack of power it seemed... but it was actually the clutch; just wasn't bad enough to think that was the problem!
I got a Centerforce Dual Friction clutch and throwout bearing. I can now spin 3rd lol, but the tranny isn't happy... seems like the extra power I am making was slipping thru the stock clutch, and now that it can get to the tranny the things getting pretty loud in 1,2,3
blackz281le
Jan 11, 2016 07:51 AM
