drum to disc install?
Old Dec 13, 2003 | 02:44 PM
SeanTimothy's Avatar
ok so on my never ending quest to get 3.73's in my car for less than 600 dollars total has lead me to this, Found a rear end with an eaton posi and 3.73's. i know i can swap in the rear no problem, what i need to know is Is 500 a good price for it, And how hard is it to convert to rear discs.....what parts are needed....
Old Dec 13, 2003 | 03:08 PM
Vader's Avatar
Does your current axle have discs, and the replacement has drums? Or is it the other way around? Or, do both axles have drums and you want to install rear discs?
It will make a difference as to what parts you already have and what you'll need.
Old Dec 13, 2003 | 03:42 PM
going from drum to disc....just had an idea, couldnt i just use my old axels in the rear end with discs?? or any way i could put the drums on in place of the discs?? oris it not that hard to go from drum to disc....and keep the disc...
is 500 a good price for the rear??? im sure i could talk down to 450...400 maybe
Old Dec 14, 2003 | 06:42 AM
ede's Avatar
ede
i've never shopped for one but i'd suspect you can find a disk rear from a 4th gen for less than 500.
Old Dec 14, 2003 | 02:17 PM
yeah but the axels stick out further dont they?makes your car look like a skate board.....
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
