first real code.....please help CODE 32
Old Jan 7, 2001 | 12:11 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
32. Fault in barometric pressure sensor circuit OR
Fault in exhaust gas recirculation valve diagnostic switch OR
Fault in electronic vacuum regulator valve
WHAT THE HECK???? i dont even know where to begin. this happens every time i drive from L.A. to S.F. or vice versa....about 400 miles. please help. i live in sf....but family in l.a. so i do the drive often.
thanks guys
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old Jan 7, 2001 | 08:46 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Because you have a TBI, its not a barometric sensor or a EGR dianostic switch, it is simply with the EGR. Either you have a bad valve, bad solenoid or some broken vacuum lines. There is a whole deal written on EGRs, check out part one and part two. EGR
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Fanatic1074
Oct 3, 2022 05:57 AM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
indygene
Sep 26, 2015 11:21 AM
