Can I bend my fuel lines coming off of the rails?
Old Jan 7, 2001 | 04:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
instead of having the lines point down torwards the PS pump can I have bend them straight out so that I can use AN fittings?
Old Jan 7, 2001 | 04:32 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
It would be very difficult. It would be very difficult to bend the lines w/o crimping one and very hard to use a bender in such tight spaces with such little line.
I wish we could have gotten together sooner, I used a Corvette fuel rail and the fittings stop right after they come out and this would have been perfect for you. I was looking for an F-body rail, but couldn't find one cheap, so I had custom lines made from the rail to the body mounted lines.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
djmarch
Aug 9, 2015 05:27 PM
