What is this bolt size?
Old Dec 17, 2003 | 03:42 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have had really bad rattle up front and i found out that it is my accesory bracket. One of the torx screws must have worked its way out because it is no longer there and that is where the rattle is. Does anyone know the correct bolt for this spot. I know the thread size because I pulled one of the lower ones but it is much longer with a 1" or so shank on it.
Old Dec 17, 2003 | 03:46 PM
ede's Avatar
ede
should be 3/8-16
Old Dec 17, 2003 | 05:35 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by ede
should be 3/8-16
Do you know the length by chance. I found a spare bolt with the same thread but it was to long.
Old Dec 17, 2003 | 07:03 PM
Guest
Guest
Posts: n/a
Use the bolt you have to figure it out. Stick the bolt in the hole till it hits the threads, mark it where the bracket is. Measure the distance from the end of the bolt to your mark, add from 3/8-1/2" to the length. Thats the size.
Its probably ~1 1/2"
Old Dec 17, 2003 | 07:54 PM
MikeS's Avatar
I usually use a toothpick or a stick or something. Jam it in there, mark where it sticks out, meaure it, and take off about a quarter inch (since blind holes aren't tapped all the way to the bottom).
Old Dec 17, 2003 | 08:38 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea I tried that but to no avail. The threads are to far deep the and the other bolts on the bracket do not reach them. I will try the toothpick method that MikeS suggested.
Old Dec 17, 2003 | 08:40 PM
MikeS's Avatar
Or just use a bolt that gets you 3/4 to an inch of threads into the threaded hole. The first few threads hold most of the tension by far anyways. There is no rule that says you have to use the entire threaded depth of the hole.
Old Dec 17, 2003 | 08:49 PM
Vader's Avatar
That's good advice. As a general rule, the strongest bolted joints use twice the diameter of the thread for engagement depth. More depth is O.K., but really no stronger. Less depth sacrifices load bearing strength.
Following that, a 3/8" bolt should have a minimum 3/4" of penetration into the base material. A 1/4" bolt should have at least 1/2" penetration, etcetera.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
