High performance heads
Old Jan 7, 2001 | 02:02 PM
StCr19's Avatar
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
Who makes the best cylinder heads? I've heard a name tossed around, AFR or something along those lines...
Anyway, who does and what is their website address?
1986 Camaro
Carbureted 305
700R4
Old Jan 7, 2001 | 03:33 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
http://www.airflowresearch.com/main.html
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Jan 8, 2001 | 07:05 AM
MEANGREEN's Avatar
If it's a 350, you could also try ported versions of Trick Flow's twisted wedge head. They're expensive though, but the best (arguably) is the ported Canfield's. Seriously high flow rates.
Dan Young
1995 Z28/M6
Groton, CT
1985 Z28/A4
(Prospective purchase)
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
