rocker knock?
Old Jan 8, 2001 | 12:29 PM
T and A's Avatar
rocker knock?
ok. As some people know, i just put a 350 target motor in my car, i stripped it down to the block and cleaned everything, and rep;aced all seals and gaskets for safe measure. I got it running well enough now that i can start fine tuning it.... but have a knock coming from what seems to be the #3 intake rocker arm, I say it because, even the slightest pressure against the valve cover in that area, will silence it. I took the cover off and rechecked all the lash on all the valves. they are perfect. does any body know what could be wrong? wrng size valve covers? will it eventually eat away at the cover, and just stop? will that hurt anything seriously? thanks, i cant work on it until spring now, but anything to get me started would be appreciated thanks
Old Jan 8, 2001 | 12:34 PM
Vader's Avatar
T&A,
A quick look inside the cover should answer any clearance questions. Some aftermarket "dress-up" kits come with covers that are supposed to be stock height, but are not quite tall enough. Many of these won't even come close to clearing with a modified head/valve/cam setup.
Later,
Vader
"I cannot take this any more... Saying everything that I've said before..."
Adobe Acrobat Reader 4.0
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
New2Chevy
Sep 28, 2015 12:35 AM
efiguy
Sep 27, 2015 01:30 PM
