one last fuel pump question
Old Jan 8, 2001 | 04:11 PM
pat85yellowroc's Avatar
can i disconnect the in-tank fp, and hook up an inline elec. fuel pump w/o taking out the gas tank?
beau-t-ful yellow 85 iroc
Old Jan 8, 2001 | 06:04 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
that's really not recommended, although I've heard it might work. The problem is that the electric in-line won't be able to pull enough through the in-tank one at higher rpms. I don't know anyone that's tried it though. You could get a Mallory 3-port afpr from summit and use the in-tank pump if you just need to reduce pressure.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
