Help! Need oil pressure sender P/N...
Old Dec 19, 2003 | 07:40 PM
Nicky71's Avatar
Car: 85 IROC-Z, 67 Corvette Coupe
Engine: 5.0L TPI
Transmission: 700-R4
Hi guys, just got a new sender P/N 14036243 for my oil pressure gauge. Is this the correct P/N? Gauge now displays 20 PSI regardless of engine RPM (no variation with engine speed).
Old Dec 21, 2003 | 01:52 PM
Vader's Avatar
Did you clean out the mounting hole before installing the new sender?
Old Dec 22, 2003 | 07:19 PM
Nicky71's Avatar
Engine: 5.0L TPI
Tried to get it cleaned out as much as possible, but you never know...
I will have to pull it back out and investigate with a decent gauge. The engine has no knocks or noises so I suspect a bad gauge rather than worn bearings. I've never had one that reads the same hot and cold, regardless of engine RPM. Only other explanation could be a stuck relief valve in the oil pump.
Old Dec 28, 2003 | 05:47 PM
Nicky71's Avatar
Engine: 5.0L TPI
Hooked a mech gauge up today and oil pressure is A-OK (30-35 PSI hot idle, 55-60 @ 4000 RPM.
Factory gauges SUCK!
89GTAOz
May 16, 2020 09:31 AM
Prodigious
Oct 4, 2015 11:20 PM
mddaniel
Sep 8, 2015 05:16 PM
solocus
Sep 2, 2015 12:14 PM
355sbcTPI
Aug 19, 2015 04:38 PM
