Maximum compression for stock 305 heads
Old Dec 21, 2003 | 09:13 AM
pecha's Avatar
Car: 98 T/A
Engine: ls1
The car is 88 T/A with 305 TPI
I am rebuilding my engine and I ordered pistons 0.30 over but my friend tells me that compression would be to big for my stock heads
So what should I do to the heads to be able to use them with my engine?
Would it possible to use them or do I have to go with aftermarket heads (no ca$h ) ?
Old Dec 21, 2003 | 09:27 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
just a .030 overbore will not raise your compression much if you have the stock type pistons. if you got dome pistons however you may have problems. the iron heads can tolerate about 10.5 to one with a healthy cam and polished chambers if you plan to run 93 octane all the time. more than that and you are looking at race gas.
Old Dec 21, 2003 | 12:27 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Don't listen to your friend.
The actual compression ratio will only be slightly higher, if at all. A replacement head gasket is thicker than the origional which lowers the compression ratio.
Old Dec 26, 2003 | 10:53 AM
pecha's Avatar
Car: 98 T/A
Engine: ls1
as I spoke to my buddy again he explained to me that he was talking about his 350 at that time
yeah that's how discussions with beer in our hands end, misunderstanding
but anyway thanks for replies
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
